the fairing bolts is stripped because of the crash. how do I get those off. and the nut on the bolt that holds my brake lever in place is also stripped to shit. any ideas
+1. stripped one of my lower fairing bolts and this method worked like a charmSVS said:For bolts, you can often Dremmel a slot in them and then take them out with a flat-head screwdriver![]()
You can also drill a row of holes with a thin drill to make a slot :coolzjbarnes said:I have the same problem. The one in the rearsets are sort of "set in" to the rearset so I think the dremel is out of the question.
This is the coolest and simplest idea I've ever seen put into action...on my own bike no less. It did result in a giant cut in m old fairings...but it doesn't matter, now I got the CF onesSVS said:For bolts, you can often Dremmel a slot in them and then take them out with a flat-head screwdriver![]()
