21 - 40 of 378 Posts
Anybody know about the gas cap's? Common thing.. I have one, can't get the lock out to change it over to my new lock...going to try and pick it..
I need a new gas cap on my 2000.. and wondering what one to go with.. 03-02-01, or 05-06?
Gas caps can be hard to pick. If you aren't going to use the old one anyways, you can just break'em with a screwdriver sometimes. Take a big flatbladed screwdriver, stick it in the key slot, put a pair of vice grips on the screwdriver, and then give it a sideways whack. That often breaks them loose internally... and then after that you can just use a screwdriver or key to turn them to open them up. Or, it at least gets the cap open, so now you can unbolt it.
Worked for me before....
Very useful info ...thanks.
I am still not sure about the FORKS. Will forks from 03 750 fit in 03 600? What kind of "tweaking" is necessary??
:wait
Everything is interchangeable. You need the forks and BOTH upper and lower triple. Other than that, direct swap. The 750 has inverted forks the 600 does not which is why you need the triples(different diameters)
I've been searching for some replacement parts for my bike, and to find info on some of my upgrades. Thought I'd compile a list of some of the things I have found out, to help others searching. Please correct anything wrong in my list or add other things. Maybe we could make a sticky?
In general:
00-03 750 is all the same. (some electronics are different)
01-03 600
01-02 1000.
750 and 1000 clipons are compatable.
Windscreen / rear seat:
00-03 750's
01-03 600's
01-02 1000's are all interchangeable
Fairings:
all fairing stays are compatable from same gen.
gsxr 600 and 750 are interchangeable from 2001-2003
gsxr 1000 from 2001-2002
PS: The side fairings from a 1000 are not really interchangable with other models.. everything else is.
Front fender:
01-03 600, 00-03 750, 01-02 1000 are the same fender.
04-05 600/750, 03-04 1000 are the same fender but won't fit the above models without modifying the rear fender mounts.
06-07 600/750, 05-08 1000 are the same fender and will bolt straight up to the list directly above (the previous generation) and will need the modification as above to fit the first gen K series.
[/LIST]
Wheels:
600 01-05 - 17x5.5
750 00-05 - 17x5.5 / 17x6.0
all interchange
Rear wheel:
1000 01-04 - 17x6.0 should also fit a 00-03 750
SRAD rear wheel - 17x5.5 (needs sprocket, sprocket carrier and all the wheel spacers too.)
05 GSXR1000, 06 600/750 and onwards rims are lighter with thinner spokes.
Rear shock interchange ability:
600 2001-2003
750 2000-2003
1000 2001-2004 (a little bit higher?)
600/750 04/05 (7mm higher)
Exhaust:
Bolt on:
2001-2003 600
2000-2003 750
2001-2004 1000
04-05 gsxr 600-750
Are all the exact same 4 bolt pattern.
Headers:
01-06 1000 headers will fit.
you have to buy the same year pipe as you do headers.
05-06 headers are the most popular bc of the m4 gp slip on.
Rear rotors:
01-08 have the SAME REAR ROTORS
Engine:
In the 750 the 1000 motor will bolt right up with the exception of the top right front motor mount. They do sell brackets that allow you a bolton or you can have a fab shop make some for you. You will need to buy a 1000 motor kit (harness, cdi, speedo, throttle body, radiator, oil cooler etc)
Swingarm:
2000-03 750
2001-02 1000
2001-02 600
These are interchangeable, but som
96-99, 00-03, 04-05 have the same in the front pivot section, but the length is different (but not much).
03 1000 on my 600 and it fit perfect, but need the rear caliper and mount...
Tail:
04-05 will fit with modifications.
Front forks:
00-03 750 forks and brakes. its cheapest, easiest and the better setup.
04 +750/600 or 05 + 1000 Better, more expensive.
hi ive just fixed a starting problem on my gsxr 750 y , it turned out it was the starter clutch, they are interchangable from the 600 750 and 100 from 2000 to 2003 , also the starter is the same but only for the 600 and 750, the starter idle gear is the same for all ,hope this helps someone, it took me hours to find out!
Figured it out, thanks very much!
so I got a complete front end from 02 GSXR600, and I'm trying find a right wheel for it, since the 02 600R has 3.5*17 wheel with 320mm rotors, does that mean any GSXR front wheel with the same size and same rotor size would be fit for it? is there other difference such as the axle diameter and so on?
From the form it seems like TL1000 S/R, 99-07 Hayabusa, 01-02 R1000, 00-03 R600/750 has the same 320mm rotors, would all these wheels fit in the 02 R600 fork? How about older GSXR600 wheels, such as 90-00?
Thanks
hello to all my suzu people!!
i just recently bought a 01 gsxr 750 love it however i really want to give it a face lift.. so my question is has any ever fabricated or bought a 04 fairing kit for your 01-03 gixxer??? i really need help bc i know ppl who can prob make it fit but if theirs a headache free kit id love to know.... thanks :hammer
Sooo.... if I'm understanding the write-up correctly I can put on my K3 750 the exhaust cans of: 00-05 750, 01-05 600 and 01-04 1000 and they'll ALL fit. Is that correct?
Yes you can, as long as it is a bolt-on (4 bolts) model and not a slip on. There might be some slip on's available for 01-04 1000...
Thanks for the help, man, just found a K4-5 600 exhaust for about 90$ new, lol, still in the box.
PS: something occured to me. Are the parts for where the exhaust bolts onto the rightfootpeg holder in the same place on K1 and K4? I'm looking at photos and on the K1 that part is in the middle of the exhaust while on the K4 it's more at the first third of the exhaust.
UPDATE: found out K4-5 fit, BUT they're much longer than K1-3 cans, about 15-20 cm longer. Which means it sticks out from the rear quite a bit.
Thanks Kerppo, for some strange reason it didn't occur to me to compare pictures, lol.
WOOT! Got an exhaust, a 02 1000 titanium.
Hm, only 01-05 had the front wheel 17x5.5? what about later models, which size are their front rims?
what about front rims off the Busa or Bandit or any other models?
