21 - 33 of 33 Posts
Discussion starter · #25 ·
the tip of the clutch broke off and the lever is slightly bent, but not that bad. and the fuel pump sounds normal. When i turn the key.. i can hear the valves opening or something, but when i try to start it, no noise at all
Just for shits and giggles, try unplugging the clutch safety switch and connect those two wires with a paperclip or a wire and try to start it... Maybe the bent clutch is just not releasing that pin quit far enough
Get that FIXED properly ASAP. Get a new clutch lever. The bike will run fine with it jumped out. But it is slightly down on power. May not be an issue for a street bike really, as it is mostly limited at the top end. but It is also a safety issue........... trust me. I have seen a guy think the bike is in neutral, thumb the starter, and the bike jumps out from under him because he did not have the clutch pulled in.
Yeah sounds the clutch switch
21 - 33 of 33 Posts
