:sad I believe my inner fork tube is bent, but its not that bad IMO. there is no spec. in the manual for checking forks tubes.
If I mount the bottom of the fork in a vice and spin the inner fork tube I can measure about .263" runout on the top edge of the inner fork tube. I cant see that it is bent just by eyeballing it. I wanted to make sure my fork was straight before i started the rebuild. Is this even the proper way to check for a bent fork? If not how do you check them? Again, the manual does not state how to check the forks.
I didnt take any pictures but maybe this will help describe what I see if I was not clear enough....
