Time for the ~30K valve adjustment/check. Am confortable with it since I've done it on diesel many times. But on thing is odd (per the service manual). It says to measure the clearance and take the existing shim measurement against the table and gives you the value of the replacement shim. Easy enough...
My intake was all within tolerance but the exhaust needed help... The measurement for the existing shims there were 1.52,1.55,1.58,1.58,1.58,1.58,1.60,1.60... nothing odd about the 1.60 and 1.55 shims but whats the deal with 1.52 and 1.58? Those are the printed numbers on the shims as best I can tell. I take it I just round down (1.52 treated as 1.50)? Just want to make sure I'm not overlooking something here. Either way, I am going to take my micrometer and double check it.
Just curious if anyone has seen this before.
