Overtightened pinch bolts
5.1K views 10 replies 6 participants last post by  Raga1000r
#1 ·
Hey guys, had a front tire change about a month ago, yesterday l was doing some maintenance to the front end and found the fork pinch bolts around the axle were freaking tight. The guys in the shop obviously didn't use a torque wrench or they thought it was a car. I assembled everything back to the recommended torques.
Now I'm worried what could have cause riding almost a thousand miles with those over torqued bolts, worried about weakening the fork clamp or something else, what do you think?
#10 · (Edited)
These twin pinch bolts have to be tightened evenly. If bolts are tightened on a hot day (warm) they will be much tighter to undo, on a cold day. Don't force, use heat light or heat blower.
This is what happens when you over tighten these. If it hasn't broken your good.
