The fan relay box has 4 wires (2 orange and red, 1 orange and white, and 1 black) coming off it connecting to the main harness. With this kit, 3 of the four wires (1 orange and red, 1 orange and white, and 1 black) are extracted and replaced by their respective colored wires coming off the black box included in the kit.
You do not want to be messing with the fan relay, what I've told you to do (numerous times) as well as others have told you - has absolutely NOTHING to do with the fan relay or the fan wiring. If you're touching any of this, you're in the wrong spot and you better leave it alone.
The black box is where the 3 wires (1 red, 1 orange and white, and 1 black) from the fan switch are connected to. The orange and white wire from the switch couples with the orange and white wire now coming from the relay box and connects 2 to 1 to the old orange and white wire originally connected to the relay box. The black and the red wires coming from the switch go straight into the black box. Another black and an orange and red wire also come out of the black box and couple with their respective wires, now connected to the relay box, and couple 2 to 1 to the original respective wires originally connected to the relay box.
Again, stay away from the fan wiring and the fan relay. What you want to mess with is the wiring between the thermal switch and the ECU - it's not directly connected to the fan or the fan relay.
There is an additional black wire coming from the same port that the black wire out of the black box connected to the fan switch. This wire goes to a ground lead that is attached to the bolt that holds down the lower air box.
No clue, if it isn't connected to the ECU on one end, and the thermal switch on the other - it's not even close to what you're wanting to modify.
All of the connections are secure and lock into place and then are covered by electric tape. I have heard that the fan motor is already grounded. So could i possibly just get rid of this additional ground wire or is that the ground wire? It would all make more sense to me if this had happened right after i installed it but like i said i havent had any problems with it until just now. So all in all maybe the aftermarket regulator i installed is crap and i just need to stick with OEM?? Hope this helps thanks for the support!
I don't care how much sense it makes to you, to be honest, you're fucking with your wiring and you're going to end up doing something bad (i.e. destroying your wiring, your fan, your fan relay, or your ECU).
Honestly man, at this point, you fail to seem to be able to follow even the most simple instructions... I would leave well enough fucking alone or don't come back here crying when you have strange electrical issues.
Seriously, find the thermal switch (look it up in a parts fiche, then find it on the bike) and tap into those *two* wires. If it has only *one* wire to it, then it is the thermocouple for the dash and will *not* trigger the fan to come on.
For fuck's sake, take a step back, take a break, read what you've been told numerous times - and then see if you get it. If not, you're going to end up butchering your wires or burning out expensive components.
I'm not going to offer you
any more advice if you don't listen to what people f'cking tell you.
