Drained the oil and changed the oil filter out today. Drained oil completely, put stuff back together, added oil to the filter, lubed up o-ring, and started adding oil. I put in about 2qt, started it up, ran a min or two, no oil in window, so added about another 3/10 a qt, ran through a min or two, still nothing. added another 2-3/10, ran through, and still no oil showing up in window.
While bike is running however, I can see oil going by the window, but nothing is settled to where i can tell if it's at the full mark or not. Not sure if i should just keep adding to see if it will eventually show up in window, or if i should just drain and start over again.
