121 - 140 of 163 Posts
Re: Updated Parts Interchange: 88-92 750 and 89-92 1100
Wheels:
All wheels interchange but you need the correct carrier.
92-93 600, 88-93 750 and 89-93 1100 are "twisted" spokes in 3.5 front and 5.5 rear but the 88-89 750 has a 4.5 rear.
94-95 750 and 94-98 1100 use the "straight" spoke wheels and these are lighter then the "twisted" spokes
I just wanted to follow up on this...
I learned that the 94-98 GSX-R1100 straight spoke wheel + cush drive and spacers (94-98) does work for the 88-92 GSX-R750 as mentioned (your 88-92 sprocket bolts right up). However, the hub is slightly offset to the right... this is non correctable with spacers/washers as it utilizes a wider cush drive and offsets the entire rim right by roughly 1cm. This is fine if you use the OEM size 170/60 rear tire but if you want to run a 180 you would have to alter the brake stabilizer bar to allow more clearance for the tire. There is also the issue of wheel alignment but I am not sure how noticeably it will affect the handling of the motorcycle...
by aldo.dauria, on Flickr
Will a 89 katana 750 wiring harness work on a 91 gsxr 750 with proper ecu?
You should start a new thread for questions like this. No the katana harness is not a clean swap... A brand new wire harness for the 91 750 is listed at $215.14 on cheapcycleparts.com... That is not a bad deal and there may be better ones out there... If I were you I'd just get a new one...
I apologize for my initial post, my computer froze.. Ugh
2012-2014 Sachs BMW S1000RR rear shock is a direct replacement for the OEM rear shock on my 1992 GSX-R750! (This means it fits 88-92 GSX-R750)
At the time that I figured out the S1K shock worked and posted the news here on gixxer.com there were a lot of other shocks in circulation on ebay listed as 2009-2011 S1kRR OEM... Maybe they were listed incorrectly but there were enough of them that it threw me off. Now it has become somewhat apparent to me that the OEM BMW S1000RR rear shock is the same Sachs triple clicker from 2009-2014. Happy hunting.
the 90 frame allows swingarm alignment , handling is effected for street
Carb slide interchange
CARB SLIDE DIAPHRAGM
Part# SD-4 Replaces OEM# 13507-17C00
Fits
1988 Suzuki GSXR750J
1989 Suzuki GS500EK
1989 Suzuki GSX750FK KATANA
1989 Suzuki GSXR1100K
1989 Suzuki GSXR750K
1990 Suzuki GS500EL
1990 Suzuki GSX600FL KATANA
1990 Suzuki GSX750FL KATANA
1990 Suzuki GSXR1100L
1990 Suzuki GSXR750L
1991 Suzuki GS500EM
1991 Suzuki GSX1100GM
1991 Suzuki GSX600FM KATANA
1991 Suzuki GSX750FM KATANA
1991 Suzuki GSXR1100M
1991 Suzuki GSXR750M
1992 Suzuki GS500EN
1992 Suzuki GSX1100GN
1992 Suzuki GSX600FN KATANA
1992 Suzuki GSX750FN KATANA
1992 Suzuki GSXR1100N
1992 Suzuki GSXR600WN
1992 Suzuki GSXR750N
1993 Suzuki GS500EP
1993 Suzuki GSX1100GP
1993 Suzuki GSX600FP KATANA
1993 Suzuki GSX750FP KATANA
1993 Suzuki GSXR1100WP
1993 Suzuki GSXR600WP
1993 Suzuki GSXR750WP
1994 Suzuki GS500ER
1994 Suzuki GSX600FR KATANA
1994 Suzuki GSX750FR KATANA
1994 Suzuki GSX750FW-NEW
1994 Suzuki GSXR1100WR
1994 Suzuki GSXR750WR
1994 Suzuki RF600RR
1994 Suzuki RF900RR
1995 Suzuki GS500ES
1995 Suzuki GSX600FS KATANA
1995 Suzuki GSX750FS KATANA
1995 Suzuki GSXR1100WS
1995 Suzuki GSXR750WS
1995 Suzuki RF600RS
1995 Suzuki RF900RS
1995 Suzuki RF900RZS
1996 Suzuki GS500ET
1996 Suzuki GSX600FT KATANA
1996 Suzuki GSX750FT KATANA
1996 Suzuki GSXR1100WT
1996 Suzuki RF600RT
1996 Suzuki RF900RT
1997 Suzuki GS500EV
1997 Suzuki GSF1200SAV BANDIT (SA)
1997 Suzuki GSF1200SV BANDIT
1997 Suzuki GSX600FV KATANA
1997 Suzuki GSX750FV KATANA
1997 Suzuki GSXR1100WV
1997 Suzuki GSXR600V
1997 Suzuki RF900RV
1998 Suzuki GS500EW
1998 Suzuki GSF1200SW BANDIT
1998 Suzuki GSX750F KATANA
1998 Suzuki GSXR1100WW
1998 Suzuki GSXR600W
1998 Suzuki VL1500W INTRUDER
1999 Suzuki GS500EX
1999 Suzuki GSF1200SX BANDIT
1999 Suzuki GSX750FX KATANA
1999 Suzuki GSXR600X
1999 Suzuki VL1500X INTRUDER
2000 Suzuki DRZ400S
2000 Suzuki GS500EY
2000 Suzuki GSF1200SY BANDIT
2000 Suzuki GSX750FY KATANA
2000 Suzuki GSXR600Y
2000 Suzuki VL1500Y INTRUDER
2001 Suzuki DRZ400S
2001 Suzuki GS500
2001 Suzuki GSF1200 BANDIT
2001 Suzuki GSF1200S BANDIT S
2001 Suzuki GSX750F KATANA
2001 Suzuki VL1500K1
2001 Suzuki VL800K1 INTRUDER
2002 Suzuki DRZ400SK2
2002 Suzuki GS500K2
2002 Suzuki GSF1200K2 BANDIT
2002 Suzuki GSF1200SK2 BANDIT S
2002 Suzuki GSX750FK2 KATANA
2002 Suzuki VL1500K2
2002 Suzuki VL800K2 INTRUDER
2003 Suzuki DR-Z400
2003 Suzuki DR-Z400S
2003 Suzuki GSF1200
2003 Suzuki GSF1200S
2003 Suzuki GSX750F KATANA
2003 Suzuki VL1500 B INTRUDER
2003 Suzuki VL1500 INTRUDER
2004 Suzuki DR-Z400E
2004 Suzuki DR-Z400S
2004 Suzuki GS500F
2004 Suzuki GSF1200S
2004 Suzuki GSX750F
2004 Suzuki VL1500
2004 Suzuki VL800 2CZ
2005 Suzuki DR-Z400E
2005 Suzuki DR-Z400S
2005 Suzuki DR-Z400SM
2005 Suzuki GS500F
2005 Suzuki GSF1200,S,Z (Bandit)
2005 Suzuki GSX750F
2005 Suzuki VL1500
2005 Suzuki VL800
2006 Suzuki DR-Z400E
2006 Suzuki DR-Z400S
2006 Suzuki DR-Z400SM
2006 Suzuki GS500F
2006 Suzuki GS500F
2006 Suzuki GSX750F KATANA
2007 Suzuki DR-Z400E
2007 Suzuki DR-Z400S
2007 Suzuki DR-Z400SM
2007 Suzuki GS500F
2008 Suzuki DR Z400S
2008 Suzuki DR Z400SM
2008 Suzuki GS500F
2009 Suzuki DR-Z400S
2009 Suzuki GS500F
