I get sick of people saying "im a big guy and a 600 just doesnt feel right" or "the 600 is too uncomfortable, so i wanted something bigger" or "you need a little 600 for the curves, the big 1000's are only good in straight lines".
If a 600 doesn't "fit" you...neither will a 750 or 1000.
If a 1000 feels too "big"...so will a 750.
If you can't turn a 1000 worth a shit, you won't be able to turn a 600 either. The problem is your lack of ability to shift YOUR weight and countersteer properly, it isnt because the bike is too heavy.
THEY ARE ALL THE SAME FUCKING SIZE.
GSX-R600
Ground Clearance 130 mm (5.1 in)
Overall Length 2040 mm (80.3 in)
Overall Width 715 mm (28.1 in)
Seat Height 810 mm (31.9 in)
Curb Weight 196 kg (432 lbs)
GSX-R750
Curb Weight 198 kg (437 lbs)
GSX-R1000
Ground Clearance 130mm (5.1 in)
Overall Length 2045 mm (80.5 in.)
Overall Width 710 mm (28.0 in.)
Seat Height 810 mm (31.9 in.)
Curb Weight 203 kg (448 lbs)
That is all.
GSX-R600
GSX-R750
GSX-R1000
That is all.
