What do you prefer and where at? Kinda interested to see where everyone goes and what they like to fill up with.
funny thing is, you could probably convert our bikes to run on propane very easily and they would probably make a little bit more power, propane works great in high compression engines. not to mention that the octane rating of propane is up there..i think like 125 or so...so with proper tuning you could be pumping out a decent amount of powerPropane
hate to break it to you but they do add ethanol. almost all brands of gasoline have up to 10% ethanol added to itI use Chevron wherever possible to avoid gasohol. So far they don't add alcohol I think as they are still allowed to substitute the Chevron patented and owned Techron(techroline) or some such.
There is the answer i'm looking for.BTW about 3HP is what you lose/gain when you swap back and forth from regular gas to U4.2 on a properly tuned 600.![]()
If I remember correctly the original question was "What kind of gas do you use?" Just about every reply to the topic has been somebodys honest answer....with the exception of a few who have waaaaay up in the thousands of post and obviously think they know more because of that.....when in reality they're no more than some pencil pushing geek who has nothing better to do that sit behind a computer all day....The cluelessness is thick in this thread :banghead
"It is a bigger number, so it MUST be better..... It says premium, so it MUST be better....... It is called RACE fuel, so it MUST be better" :rolleyes
isnt that how most of these "gas" threads go?The cluelessness is thick in this thread :banghead
I run CAM 2 in my Craftsmen lawn tractor!!! (goes bad after a week or so of sitting in the jug rather than let it waste i burn it up in the tractor)
