Kk, so just finished the jet kit, and a bench sync. Carbs are cleaned throughly. I can't get the damn idle to function properly. At proper temp, the idle is perfect - smooth, no pulses. If I Rev it, the rpms will drop down normally, hang at 2k for about 5 seconds, then drop down to normal idle.
If I loosen the adjusting screw so that it idles at 1k, the bike revs fine - rpms drop without hanging. If I raise it up, the issue is present. I've tried carb syncing and I must not be that good at it. I've got a set of ABN vacuum gauges and if I adjust any, the rpms just shoot to 5K and I can't get them to drop back down.
I've sprayed carb cleaner around the block head, intake manifold, carb boots, and any other spot for a vacuum leak to exist. NO change in rpm. I've adjusted the throttle cables and checked to make sure the choke isn't sticking...
I'm about to take the damn thing to a shop since at this point, I've had the carbs on and off longer than I've been riding this season.
Any thoughts? Oh, and it's a 97 gsxr 600
Sent from my Nexus 6P using Tapatalk
