Upshifting mid corner
7 reading
3.1K views 47 replies 20 participants last post by  cehowardrx7
#1 ·
Ive got no confidence in upshifting during a high speed corner (80mph).
Even clutchless upshifts seems to shake/wobble the bike, so do you have any advice?
Thanks
#3 ·
In the UK we have corners that can go on for over a mile, so changing up from 3rd once or twice, while being banked over about 30 degrees is often unavoidable.
I probably make it worse because it worries me.
Thanks
#14 ·
so your at 80mph 3rd gear, entering a long corner that lasts for about a mile and you suggest short shifting, but what about when you need fifth?
I want to be slowly increasing my acceleration too
#9 ·
SHORT SHIFT! If I'm leaned over way too much in a corner to shift.... I short shift into the next gear before I tip the bike in and just hold it WOT.
#10 ·
+1 to Will. BUT, I am SURE he is doing it much faster than you are. Upshifting should never upset the bike unless you are doing it wrong. It can happen sometimes if you are at extreme lean angles and near the limit of traction. But even then it's about being smooth, which I would wager you are not.
#12 ·
on a 600 yeah, but on a 1k its highside or backflip :scared depended on gear selection and gearing itself
#24 ·
:cursing
what's wrong with a K1
#16 ·
Really you do need to change gear on such a long corner, if you rev the engine to 14K while banked over, the bike feels unstable.
Their seem to be 2 schools of thought here:
- Don't change gear on a corner by short shifting or
- Change gear very smoothly if you have to
#18 ·
my suspension probably isn't setup properly, but i do find high rpms on all bikes a bit skitish, cars too.
Anyways its only a K1 600, a new set of Ohlins costs more than i paid for it and ive only been riding for 2 year now.
#19 ·
Then you might have other issues with high RPMs. Have you ever thought it could be all in your head? what I'm saying that is if both car and cycle feel bad to you at high RPM then you may have some underlining issues that YOU need to resolve and not the equipment.
#21 ·
You think i should see a psychiatrist about my high rpm issue :LOL
High rpm's and top end HP while cornering is more unstable than low rpm/hp, thats a fact.
No it is NOT a fact. It can be VERY dangerous to go high speed into a corner with low rpm. There is clearly a LOT you need to learn. My suggestion would be to get your ass to a race track (proper environment) and take a track day class or race school with someone who can teach you in real time.
#27 ·
I would look at the gearing as well as the chassis set up... Suspension settings, tire pressures, chain adjustment, etc... Next would be rider body position, grip on the bars, foot peg pressure etc... If my flexy frame ZRX can go around a corner smoothly, surely your GSXR can :)
#29 ·
Who pulled this old thread back up?.
The Answer
The reason for my bike getting upset in a mid corner gear change was rear preload, it only had 5mm Preload as the shock was tightened right down. Any wrong movement at high speed would start a wobble.
At the time i thought i had a problem changing gear but no it was the suspension.
Thanks
#31 ·
I wanna see the mile long curve :eek
I think somebody might have made a trip to the U.S. to run Talladega and picked the wrong "Talladega".
:biggrin
Edit: as if anybody would come over here to run little T. :lol No disrespect to little T, i like it...but im just saying....
#32 ·
I would photograph one for you but i haven't got a helicopter :lol
A friend/veteran bike racer went out on my bike and told me it was prone to high speed wobble due to the hard rear suspension. Now ive backed off the rear shock it rides much different.
Also ive put a 63 tooth rear cog on, so my bike wont go over 120mph anymore
#33 ·
Glad my suggestion worked for you :)
You want both the front and the rear of the bike to be set up properly... So, first things first - I would start with the factory recommended settings front and rear for preload, compression, rebound, as well as where the forks are in the trees (higher or lower than stock?), as well as checking the rear shock for any changes in ride height.
Next, get your racer friend to help you set the sag. Make adjustments as needed to the preload to get as close as you can to correct. 25-35mm is a good ball park to be in. There are plenty of instructions on here about how to do it.
Once the sag is set, you can start to make some slight adjustments to the compression and rebound damping. Does the bike feel like it is hard to turn or resists entering a corner? Does it turn too quickly? Take a few rides up and down the same roads and take some notes. Mark down the compression and rebound settings. Make adjustments two clicks or one turn at a time so if needed you can go back 1 click or 1/2 turn. Again, take notes of the changes, and try to run up and down the same roads as much as you can.
Be careful! Speed is not critical, but try to go at a speed you normally would. What feels choppy at 30 mph will feel better at 60mph usually.
What the heck are you doing with a 63T rear sprocket? Are you riding the rear wheel down these 1 mile long curves? A big sprocket like that will also affect the handling...
#34 ·
Ha ha, well ive turned this K1 600 into a stunter with all the mods, its had a few accidents but its served me well as a learner.
Im getting another road bike soon a K6 750, that bike will be kept nice.
