Titanium Headers K5 600
1 reading
8.3K views 12 replies 10 participants last post by  MokujinX5
#1 ·
Does anyone on here know if the titanium exhaust headers from a GSXR 1000 will fit on a K5 600 ?
#2 ·
the k1 k2 can fit k5 gsxr1000. tat all i know....
#4 ·
I almost bought some 1000 Ti headers on Ebay but I realized that the header and midpipe on my bike are welded, and I am not sure you can weld Ti and SS so I changed my mind and just bought some exhaust wrap.
I think you would have to bolt on the whole 1000 exhaust.
#5 ·
Yes the 2003-04 GSX-R1000 header does fit on the 2004-05 600s and 750s.
I'll post more pictures if you want. Gimpsta said that there's a 7lb. difference between the 2 exhausts. If your'e gonna do the swap you'll need the 1000 midpipe also. Cause like Mr. Potato Head said, the 600/750 exhaust is 1 piece (header and midpipe) while the 1000 is a true slip on configuration (2 pieces, header is seperate from midpipe). Don't worry about the SET valve; without the cables hooked up it's disabled and the valve stays open.
Here's a picture comparing the two exhausts...
The 600 exhaust is on the left... 1K on the right
Here's the header/midpipe conjunction for the 600 exhaust:
Here's the same header/midpipe conjunction for the 1000 exhaust:
(Sorry for the fuzzy picture)
The 1K header/midpipe mounted on my bike:
#6 ·
Top portion of 600 header
Top portion of 1K header
When I bought my header/midpipe combo off eBay, the damage came out to $120 shipped.
I've got an extra 2003 1K header if anyone wants it... it just needs to be cleaned up.
#9 ·
No i didn't I just like the look. I personally like that its smoother up on the top end. The 7lbs was a difference of the whole set of headers/mid and exhaust.
But i love the discolorations as you get the mid pipe hott.
#10 ·
Is it just my bad eyesight or do the secondary pipes on the 600 header on the left look to be of a significantly larger diameter than the 1000 header on the right?
#12 ·
it just bolts up.
u hve to loosly put the headers to the engine block then attack the bolt under the rear set.
Then u can tighten down the headers to the engine.
#13 ·
I think it's just the lighting in the picture, up close the 1000 header has slightly larger secondary pipes. I swapped the header for the fact that you have a larger selection of slip-ons plus I talked to a couple exhaust companies that don't make a header (IXIL in particular) and they said that most of the 600 and 750 riders are swapping to the 1K header as a poor man's "full exhaust" system.
