SLIDERS - 1993 gsxr 1100 w
1 reading
7.6K views 6 replies 5 participants last post by  TJS
#1 ·
Hi guys, cheers from Portugal...
I am looking for some sliders for my 1993 1100w, the ones that don´t need to cut the fairings, does anyone have ones... can´t find none...
here a picture from my bike...
thanks in advance.
Nelson Martins.
#2 ·
You will find some info on them, but very limited. The shape of our frames makes frame sliders impossible. So you would be into something that is engine mounted, and you will find that most if not all will lean away from this as a damaged fairing is better than a destroyed block.
#6 ·
#7 ·
Gas tanks are hard to find. So, the high mount of the black slides are from a TL or K gsxr.
Small white under those are bar ends shaped to fit.
Finally the knee pucks, down low can hide under the plastic for extra motor protection.
There is a company in the UK that builds a complete kit for about $300. eg fork sliders, frame sliders that connect to the lower engine aluminum support, bar ends, rear spools,...check ebay uk
