Tools you'll need:
T25 tamper-proof torx bit.
Here is a few pictures of what one looks like.
Steps:
1. You'll need to prop your tank and locate the dealer terminal. It will be a white terminal with a white cap that has 5 black rubber circles on top.
Here is a pic of what it looks like. NOTE THAT YOU WANT TO PUT THE PAPERCLIP IN THE TWO HOLES ON THE END WITH THE COLORS I HAVE SHOWING IN THE PICTURE. The red/white & black/white
Here is what the cap looks like.
2. Bridge the gap with a paperclip. My picture shows how I did it.
3. Once this is done, look at your gauge cluster (turn bike to on, but do not start it). My cluster was reading how the picture is below. You want the dash on the left to be in the middle, NOT the top or bottom. Some people like to get the TPS to where the dash bounces back and forth between the top and middle, that's your call. I have mine right in the middle.
4. Locate your TPS. It will be on the right side of the bike, back behind some wiring. I had to move a cluster of cables out of the way to see mine. I remove my right side fairing as it gives you a view into where the TPS is located.
Steps:
