Alright, this is now the second time I've had headlight issues on my 2002 750. The first time it was the infamous corroded connector in the right fairing. That would cause my headlights to stop working all together which was really scary at night when it would go out. I fixed that by jumping that connector because cleaning the connector still didn't want to work. So, that fixed it for about a year and a half. Today I got up at 7:00 to go to class and everything was fine. I drove around a little later and my high beam indicator LED was not on in my gauges. So when I got home I checked it out and sure enough my high beam bulbs were not on. I tried low beams and that worked just fine. I took the front fairing off and replaced the bulbs. Same issue with the replacement bulbs(which were actually the factory bulbs). I changed the fuse and that didn't work either. I wiggled the connector that I had previously jumped and still nothing. I am completely at your mercy. I need help.
Jarrett
Jarrett
