In Australia.
So when my son had his little crash the other day he managed to smash the key to bits but not break it, basically it is now a steal pick with a key shape on one end but it still works.
My problem is it is the only key we have and I'm lead to believe it is / was chipped to talk to the ECU.
We've swapped the engine out into a new frame and it will not start, I ran the fault codes and got a C21 and C42, the C21 is the Air Intake Temperature sensor which is irrelevant.
But the C42 is the Ignition Switch Signal or the Immobiliser.
When we hit the key it sounds like a very short prime but it doesn't send any fuel or start obviously, it does crank over nicely though which we were pleasantly surprised about.
So the question is how do I bypass the immobiliser and stop the C42 code so the bike can start ? There's got to be a simple fix for track bikes, surely this happens often enough.
The red key light on the dash is flashing quickly too.
Below is a video of the damage.
https://www.youtube.com/watch?v=GS6YcZgmz40
