Still driving home with it. Kind of an impulse buy. I couldn’t pass up the deal. Details to follow…
Poss Dyno - call Coleman Powersports in VA and speak to Rick Beggs .. Motorcycle Mall in NJ is good tooNot too long after my last post, I injured myself (not seriously), ignored the issue for a few months and have been out of commission for the summer as a result. Just now starting to get back to normal. Unfortunately, this meant I have missed the 2023 season. I am, however, planning to be ready for spring 2024. This also means I have more time and am planning several changes to my setup.
Everything I sent out for machining and order has been received. No real hiccups. The quick access clutch cover did take longer than expected (4 months) but glad to have it. To my knowledge, Warp Speed Racing is your only option for this thing so if you're looking for one, he's the guy you want to contact.
For those who are curious, this is what is meant by breaking into the oil galley when boring to make clearance for the oversized piston sleeves. A little epoxy solves the issue but you then are required to run a top end oiler. I have also seen someone cut out this area and epoxy a brass tube in there but not the direction I wanted to go.
So what's new for 2024? One of the biggest challenges I've come across is booking some dyno time. Simply put, if you're running carbs, no one will even book you in for a baseline run (in the Northeast anyways). No one wants to deal with carbs, even if you are going to do all the tune work. Also, I'm not too stoked about having to find a carb/jet setup that works for both all motor and nitrous. I've spent quite a bit of time researching fuel injection conversions and what's required to do it well for race applications. After considering what's involved and the pros and cons, I've decided to convert over. I'll be running 01/02 GSXR 1000 throttle bodies (42mm) and powering it all with a Maxxecu Race H2O engine management system. What won me over is how powerful the ecu is. It does EVERYTHING imaginable and does it well. It will not only do the basics (control ignition, fuel, etc.), but it's also a progressive nitrous and boost controller in addition to being a robust data logger. It even offers an app to run virtual dash with any android device. In the long run, it's the way to go. I'm going to fully document the process in detail so the next guy will have an easier time. There's more detail, but I'll save that for a post in the future.
Other changes: Moving to a DME swing arm (uses a Gen 2 Hayabusa rear wheel assembly), CBR 900 front wheel setup (smaller diameter which will allow me to use offset triple clamps), Catalyst 3/4 Hayabusa turbo upper (way more aerodynamic), aluminum 1.5 quart fuel cell (have another tank I'm going to hollow out - the NOS tank will move over to my track bike), and a bunch of smaller changes.
^^^^^^ This is what I am very interested in. I researched this quite a bit a few years back, as it's basically the last serious mod left to do to my Gixxersarous, to make it a truly modern, retromod.I've spent quite a bit of time researching fuel injection conversions and what's required to do it well for race applications. After considering what's involved and the pros and cons, I've decided to convert over. I'll be running 01/02 GSXR 1000 throttle bodies (42mm) and powering it all with a Maxxecu Race H2O engine management system. What won me over is how powerful the ecu is. It does EVERYTHING imaginable and does it well. It will not only do the basics (control ignition, fuel, etc.), but it's also a progressive nitrous and boost controller in addition to being a robust data logger. It even offers an app to run virtual dash with any android device. In the long run, it's the way to go. I'm going to fully document the process in detail so the next guy will have an easier time. There's more detail, but I'll save that for a post in the future.
Stole that tank.even in 2022 prices were high. But in 2024? Worth 12 to 1500 bucksI got it pretty cheap imo given they rarely come up for sale - $700. That's quite a bit less than I paid for my 750 tank. I actually bought it before I knew I was buying this bike so it worked out perfect.
