I got a couple of far away an a couple up close. Can you tell me anything by the looks of them? [IMG]http://img340.imageshack.us/i/bike1ml.jpg/[/IMG]
jacker2020 · Registered Joined Apr 20, 2010 · 312 Posts Discussion starter · #1 · Jan 6, 2011 (Edited) Only show this user I got a couple of far away an a couple up close. Can you tell me anything by the looks of them? [IMG]http://img340.imageshack.us/i/bike1ml.jpg/[/IMG]
SVS · Bearded Viking Admin... Joined Oct 12, 2002 · 125,515 Posts #2 · Jan 6, 2011 Only show this user Not really :lmao
SVS · Bearded Viking Admin... Joined Oct 12, 2002 · 125,515 Posts #3 · Jan 6, 2011 Only show this user ...remove all the embedding stuff - should only be http://img209.imageshack.us/i/xxxxxxx.jpg ...between the
SVS · Bearded Viking Admin... Joined Oct 12, 2002 · 125,515 Posts #4 · Jan 6, 2011 Only show this user One set of tags (square bracket) for each pic.
jacker2020 · Registered Joined Apr 20, 2010 · 312 Posts Discussion starter · #5 · Jan 6, 2011 Only show this user Yea I saw that. Working on it now. Thanks.
jacker2020 · Registered Joined Apr 20, 2010 · 312 Posts Discussion starter · #6 · Jan 6, 2011 (Edited) Only show this user [/IMG]
jacker2020 · Registered Joined Apr 20, 2010 · 312 Posts Discussion starter · #7 · Jan 6, 2011 Only show this user I give up just delete this whole damn topic.
600k2 · Not the powers that be, not even close. Joined Jun 1, 2009 · 26,130 Posts #8 · Jan 6, 2011 Only show this user post the links to the pictures
SVS · Bearded Viking Admin... Joined Oct 12, 2002 · 125,515 Posts #9 · Jan 6, 2011 Only show this user Copy the part of the address that begins with http and ends with .jpg Click the "Insert Image" button (the little yellow landscape icon above the text box) Insert what you copied Move down two lines Repeat Post
600k2 · Not the powers that be, not even close. Joined Jun 1, 2009 · 26,130 Posts #10 · Jan 6, 2011 Only show this user use firefox and click on the image in imageshack to make it big, then right click and copy image location and then use image tags. :cheers works: http://img340.imageshack.us/img340/3750/bike1ml.jpg vs does not work: http://img340.imageshack.us/i/bike1ml.jpg
jacker2020 · Registered Joined Apr 20, 2010 · 312 Posts Discussion starter · #11 · Jan 7, 2011 Only show this user
600k2 · Not the powers that be, not even close. Joined Jun 1, 2009 · 26,130 Posts #12 · Jan 7, 2011 Only show this user looks tucked under to me right here. SRADIATOR will give more insight i am sure.
jacker2020 · Registered Joined Apr 20, 2010 · 312 Posts Discussion starter · #13 · Jan 7, 2011 Only show this user In that one I have it sitting straight up against the wall with the bars straight ahead. idk if that matters or not.
piester · Premium Member Joined Apr 24, 2010 · 1,416 Posts #14 · Jan 7, 2011 Only show this user my guess goes for tucked also.
THE SRADIATOR · Registered Joined Nov 18, 2001 · 22,855 Posts #15 · Jan 7, 2011 Only show this user This one looks about right to me. The relationship of the front wheel to lower faring looks to be in order. You can pull the tank and air box and use my magic measurement to be sure though.
jacker2020 · Registered Joined Apr 20, 2010 · 312 Posts Discussion starter · #16 · Jan 7, 2011 Only show this user Well I will have them off soon anyway. So what are the measurements again?
THE SRADIATOR · Registered Joined Nov 18, 2001 · 22,855 Posts #17 · Jan 7, 2011 Only show this user 26 7/8ths.
