I have adjusted my chain a couple time and it seems like I either overtighten it or its too loose. I was wondering what methods you guys use to adjust your chain correctly. For example....
1. Do you sit on the bike and have someone adjust it or do you calculate it while off the bike?
2. Does sitting on the bike cause the chain to get tighter or just the opposite?
3. What methods are the best to measure the up and down play and how far along the chain should this be done?
4. Does your chain hit the bottom of the swingarm when you move it upward at any point (including the black rubber chain guide/slide)?
:confused
:confused
