Ok, First details on the bike:
02 GSXR750 Blue/White with 8088 miles
now it has almost 9100 after two weeks
Hindle Full Exhaust
Yoshimura EMS
BMC Air Filter
Iridium Plugs
Sproket Specialists Sprockets
Don't know the chain manufacturer
and it has some brand Air Shifter (can't find a maunfacturer)
Zero Gravity DB Screen and the Flush Mount LEDs so she pretty
Any now to the problem and the things I have tried:
The problem is when it heats up after it gets over 170-178 if its hot or sits in the sun it will sit and crank all day. If you goose the throttle some times she fires right up sometimes it takes some more work to hit the throttle just right but its a FI bike so this don't make sense to me. At 1500 RPM it seems like its jerky or hiccups which could just be tuning issues.
And due to the fact it was raced. The guy before me installed a switch for the fans to be constantly on (makes sense to me for when you are sitting at the line maybe not up to temp, I have never raced so I dont know why) but with the switch off the fans won't kick on no matter the temp.
This leads me to believe that a temp sensor, specifically the ECT isn't working correctly and therefore could be sending the FI the wrong information on how much fuel to dump in because the ECU cant tell what temp the bike is at.
So I went to the local Suzuki Dealer and wasn't really impressed with the guys that worked there but asked them what could cause this. They said unplug the EMS maybe its bad if it is it will just go back to stock tuning. So I did and the bike immediately threw a FI light and a Chec code and wouldnt start. I plug the EMS back in and if fired right up I dont know what code cause i dont have a mode seletor switch yet. Sorry for the long post but I just got the bike and the first day I got it it started doing this and I live in NC so its always hot.
Amaze me withyour wisdom.
Hindle Full Exhaust
Yoshimura EMS
BMC Air Filter
Iridium Plugs
