I'm trying to install a switch that will cut off the headlight but I need to know what wires to cut. I only need the switch to cut off the low beams, but I cannot tell if both bulbs are lit when the low beams are on. Any help would be appreciated.
****Alright I cut the black/white wire from the lower light and the black/blue wire from the upper light so their is no low beam now. I just need to figure out how to wire these wire's to the switch, every time I try I blow the Hi beem fuse. Any suggestions? I'm running out of fuse's!!!
