D.I.Y: Fuel pump replacement/upgrade
101K views 19 replies 15 participants last post by  Doubledogdown
Step 11: Now remove the old fuel pump connector by cutting the connector off. Crimp on new spade connectors onto the fuel pump wires. Positive is red and ground is black. The positive and negative is marked on the fuel pump. Reconnect the fuel pump wires and reassemble the unit. (Gasoline is dielectric, just means it doesn't conduct electricity) Just reverse the instructions for separating the fuel pump from the unit to reassemble.
Step 12: Make sure the unit is assemble correctly. Till the unit until the fuel level arm is 90 degree's point towards the floor. Insert the fuel level arm into the fuel tank first and then slowly wiggly the unit back into the fuel tank.
Step 13: Before bolting the unit back onto the tank, make sure the fuel port is facing the right way.
Step 14: Apply lock-tite to each of fuel pump unit retaining bolts and tighten down to 7lbs in a crisscross pattern. 7lbs is hard to measure so hand tight.
Step 15: Reattached the tank back onto the bike by installing the rear tank retaining bolt first.
Step 16: Reconnect the fuel line back onto the fuel rail. Press the line back onto the fuel rail and make sure the green tabs are lineup with the open space on fuel line connector. Once a click is heard, the line is attached properly. Reconnect the fuel pump harness by pressing both ends back together until a click is heard.
Step 17: Reinstall the battery. Power on the ignition and set the run switch to run to pressurize the fuel system. DO NOT START THE BIKE. Check for leaks and if no leaks are found start the bike. Let the bike run for a few minutes while checking for leaks again. Once no leaks are found, shut off the bike.
Step 18: lower the tank and reinstall the front tank retaining bolt, reinstall the fuel tank trim pieces and reinstall the seat. All done.
Hope this was helpful, happy holidays and ride safe.
I'm at autozone trying to buy an accura or honda fuel pump and these guys are saying no way ,they are way different....whom ever told you that is high.but they both look high to me. So it really fits rite in other than cutting that one spot?
