clutch / tranny questions
479 views 9 replies 6 participants last post by  31807
i have the same problem in 2nd gear, ill WOT and it will sort of do a jump at around 5,500 rpm, then around 7,800, then another one or two. It is not skipping teeth I am almost certain. A friend of mine said it could be some engaging thing wrong with 2nd gear, something that helps put the tranny in gear, not sure at all but maybe this will help answer this problem cause I really need to fix this problem, anybody?
