1 - 2 of 9 Posts
Check your battery voltgae and the connections to it, make sure it's tight and not corrosion built up on the posts.
then check your wiring connectors making sure they're tight and stuff.
Good luck!
Got to thinking about this some more, you said that you can turn the key a few times and it comes back on. Maybe the key switch is loose
Is there some play when you turn the key or was the ignition ever replaced and the torque bits on not tightend all the way up.
1 - 2 of 9 Posts
