1 - 1 of 5 Posts
The stanchion tubes of the 1100 are longer, therefore a 750 spring and cartridge tube are short for use in an 1100. To lengthen you could use a spacer for the spring (but the 750 spring rate is softer than an 1100), and the cartridge rod could be extended in theory (with a coupling and extension rod). In theory because its questionable if you could find a rod and coupling to match the cartridge rod threads, so you may be looking at custom machining these. Besides the damping characteristics of the 750 cartridge is likely different than the 1100. and questionable if you could have enough adjustability to get enough increase/decrease in damping
1 - 1 of 5 Posts
