Hey everyone,
I recently bought a 2013 750 and its my first gsxr. Been doing some of the bigger maintenance items since I just crossed the 30k mile mark. Just changed spark plugs, oil and filter, GPS since it was indicating gear changes on its own, and its running good for the most part. One thing that I haven't had much of a chance to look into yet is the idle.
Essentially, it idles fine on cold start and hovers around 1400rpm. If I start it again after a little bit, it'll go to about 1000-1200rpm and there's a chance it'll die unless I crack the throttle. No stuttering or lack of power once started so I wouldnt think fuel delivery would be a culprit. I'm going to clean the air filter since it needs it, but what issues do you think it could be? Just low idle setting? There's one ignition coil that probably needs to be changed but I need to check resistance on it.
Also on a different note, my shifter seems super sensitive. If I accidentally tap it, it acts like its expecting a gear change. Are gsxr shifters just sensitive? Coming from a 22' R7, where I lifted up on the shifter to take the slack out so I could shift smoother.
Any advice or input is appreciated. Thanks!
