check out this link
http://www.visordown.com/motorcyclenews/view/2009_suzuki_gsxr1000_pictures/5585.html
If that is true, there's a big chance they will sweep the floor again with the other 1000'sHOT HOT NEWS Directly from Paris
The new gsxr 1000 will have 191Hp and 5 kg less and 5 more nm
http://www.bike.se/blog/
You are so F**** lacyTina we don't speak arabic
But I hope the midrange power will be the same as the K7, The K5 had a huge midrange but if you take the Cat off the K7 it has a huge mid power to.
So I hope that stays the same with the K9
Those numbers are about the same that Yamaha has quoted for the 2009 R1.HOT HOT NEWS Directly from Paris
There is something callde translation tool
Updated: GSX-R 1000 by 191 horsepower to 2009 and the new Gladius for women
Today 11:44 | Off: Morten Brok
The presentation has just started. After a series of speeches by the Japanese, a little marketing talk about Suzuki celebrates 100 years this year and thousands of small dainty sandwiches to CRAM in itself, it has started.
Direct from Suzukis presentation in Paris, we can report it to 2009, a new Suzuki GSX-R 1000, which was expected. In addition, a new gliders called the M1500, which of course is based on the M1800. Bakdäcket measure for the rest 200 in width. More exciting is that it will be a completely new model called the Gladius 650, primarily targeted against women.
In the case of GSX-R 1000 is alleged to have 191 hp and five kilograms less weight. In addition, another five Newton Meter ... Gött mos! The engine is six inches shorter and more compact, also with less kind. Even wheel base has become shorter.
Also, you can talk about that it will be another new model from Suzuki to launch at the exhibition in Milan.
We will return with "real" pictures as soon as possible. In the meantime, then you can settle you with these directly from your mobile phone ...
svenska » engelska Översätt
Föreslå en bättre
The links isn't showing the article about the new 1000 anymore.I translated to Dutch, and it seems the true.
More Horsepower and less wheelbase.
How do they keep the frontwheel down :lol
remember the K7, i gained a few kg's after the K5.With 191HP, I'm sure the motor will be awesome. But only a 5kg weight reduction? That is only 11 pounds. It will still weigh 24 pounds more than the Honda CBR1000RR!!!!!!
BTW, did Suzuki actually say this bike would be Revolutionary??
Yeah, but doesn't the Honda's cat weigh something too? Swapping the exhaust on the Honda will lower its weight further.remember the K7, i gained a few kg's after the K5.
But only the cat weights 6 kg's.
Take it away and mount some good aftermarket pipes and it will lose at least 7 kg's
