1 - 1 of 1 Posts
ByLoeCellHi
Discussion starter · #1 · (Edited)
Picked up this 2006 GSX-R 600 back in May. Previous owner thought the engine was toast. Found out the timing was off by a tooth, which caused the 2 burnt valves. Swapped the valves, installed a new head gasket, set the timing correctly, and now compression is 170 across all 4 cylinders.
Here’s how I did it:
compression test
1 - 1 of 1 Posts
