Hello, I own a 2006 GSXR 1000 with 21k miles and I’m having some trouble. The bike has a mildly rough idle I mean like a 100-200rpm flutter and I can hear the bike stuttering at idle. At first I tried to adjust the idle assuming it just needed to be adjust, didn’t fix it. I then tried some trouble shooting, I made sure that the coils were completely plugged in, the air filter was not dirty and everything was plugged in. I had a spare ecu from the same year swapped it didn’t change anything (I had a flashed one in it). This is were things get interesting, there are 2 plugs on the air box a green one, larger and closer to the right side of the bike and a smaller blue one closest too the throttle cable/idle screws. Upon disconnecting the blue one (part number 15620-29G00 on the airbox diagram) the idle issue goes away and sounds much better. The bike is not throwing any codes until I unplug that blue sensor and I believe I have found the issue does anyone have any advice on further diagnosing it so I know what to replace?
