Hello evryone,
I'm having an issue with my TPS. While I was riding the bike threw a C40 code (ISC Valve). While checking the code I noticed the TPS is responding very slow whenever I release the throttle. Now it's in the right position (c-00) on idle and raises to the top position once the throttle is twisted. But once I fully release the throttle it takes 4 to 5 seconds for the line to go back to the idle position. I know this isn't right but can't figure out why it's taking so long. Now my bike has ASV levers, Brembo clutch master cylinder and a Brembo micro switch as the clutch switch. I'm thinking my micro switch may have gone bad so I ordered another one. I'm hoping that's what's causing my C40 code. Anyone have an idea what would cause the TPS to respond so slow when I come out of the throttle. Thanks for your time!!!
