I know there are a million thread's regarding this issue, but non of them has my answer.
I have a 2006 GSXR 1000 which I am helping a friend fix. The short story. They were out on the track. As he came into the pits, the bike switched off and showed the "Check" on the dash. Pushed it down the pit lane and from there it is dead. NO THE BIKE IS NOT STOLEN...
The Fuel pump does not prime or anything. Please note there are no FI errors on the dash.
I have checked the following:
Kill switch
Side stand switch
Ignition
Tip over sensor
Fuel pump relay
Neutral switch
Fuses
Clutch switch
ECU
There is no "while block type plug" in the tail of the bike.
Is there anything else I am missing here??
Kill switch
Side stand switch
Ignition
Tip over sensor
Fuel pump relay
Neutral switch
Fuses
Clutch switch
ECU
