Any know this????????????
747 views 18 replies 11 participants last post by  shawn-g
#1 ·
Has anyone heard, of someone who got the K5 chromed having issues with the frame snapping??? i haven't seen any of them on here....just curious
Cause i would think that if there was a frame issue, (which i don't think there is) that those would be the first to go
#9 ·
A friend of mine cracked 3 wheels after chroming. They all cracked where the spoke mets the rim. He blamed it on the chroming process.
#10 ·
Look up hydrogen embrittlement. If done in an old shop that only does harleys and takes shortcuts, then maybe. Chroming aluminum is a delicate process of which most places will not guarantee it to not flake etc.
Take it to a good place that knows what they are doing. Usually the places tht know what they are doing will do aluminum. Places that only do steel will fuck it up but will also usually turn you away and recommend someone that does aluminum.
#12 ·
Chroming wont effect the frame??? Um, do u guys know the chemical processes that go into chroming?
D
Yes, I do. Won't affect the frame.
Ok, no u dont. To say it wont effect the frame is retarded. One thing suzuki is way against, and teaches us about the bad things from doing it. About the only safe thing is powder coat.
D
#14 ·
chroming will effect the strength of aluminum. I've seen many a wheel crack after chroming and slapping down a tall wheelie (or other abuse). I thought this was common knowledge... but since there is no concrete evidence that the K5 has a week frame I wouldn't rely on what I've 'heard'. we all know about "heard", she's a lying bitch.
by the way +1 on the anodizing. I've always wondered what that would look like. maybe if they had a color theme or a secondary color for all the aluminum. but i'm happy with my black frame.
#19 ·
I didn't want for this to be about what it looks like or anything like that....just wanted to see if the crome frames were holding up....
or if the stock look was the only ones that were snapping...
Chrome ones aren't on the track and hitting the walls at 100 as was pointed out earlier....meaning no frame issues....or am i looking at this wrong??
