I have a 95 gsxr 750 I'm new to the bike world and I love it so my problem is I just replaced the friction and steel plates and springs and now when I start the bike and pull the clutch in and put it in 1st it jumps and dies any help would be great
Basically, Yes!Or that like the 1100, one of the OEM components at the back of the stack needs to be removed outright. Not sure if that is the case with Barnett kits for the 750 though.
it should be!Nothing was bent but when I pull the clutch the arm moves about a 1/4 to 1/2 inch is that enought
If you pulled the small arm atop of the clutch cover by hand, then you don't have it connected correctly.I took my hand and pulled the arm as far as I could go and my buddy put it down in first what and it still did the same thing any ideas
As long as it's not your wife's table! :smackbottomI ASSume that none of the steel plates were bent or noticeably warped?
Laying them flat on a glass or marble table is a good way to check!
