Do those two plastics comes OEM new with white Warning Suzuki stickers?
COVER RH 94670-01H00-YKV
COVER LH 94680-01H00-YKV
Thank you.
Thank you.
Yea, thats what i have seen when was looking at the plastic, 7 bolts and 1 clip. Thank you very much.Im not sure about the stickers, however call the dealer and ask. I work at a car dealership and I can order any sticker, anywhere on the car so if its jsut the stickers you are after they should be able to handle it.
As for removing the intakes, no the headlight doesnt need to come out. Undo your 3 fairing bolts, there are 3 above the intake, one is under the cluster, one beside the headlight, and 3rd is just under the windscreen. Then pop off the under cowling above your tire, adn there is a bolt on either side just under the intake tube. Don't forget the clips near the frame either.
so in total, 7 bolts and 1 clip per side.
