You can remove and reuse the bearings if they are good if you have the right tools... But as stated, the stock wheel bearings (two in the wheel, one in the cush drive hub) are fairly cheap. They should be sealed on both sides. The cush drive bearing is more expensive.
I check bearings every time I have a wheel off a bike by hand. I also clean off any chain lube mung and lightly lube the bearings with good grease - helps prevent moisture from getting in...
In many cases, the suzuki wheel bearings are the same as kawasaki or other brands - as long as the sizes are the same and the seals, find the cheapest one. I would go with a name brand bearing though, if not OEM - like SKF or Timkin. We also sell a lot of Worldwide Bearings Ceramic bearings... Very low friction and reduced rolling resistance.
Bearings don't have to be installed on a press - I have always done them with a set of aluminum fittings and a mallet. Just don't forget the inner sleeve
