I can't see to figure out how to get the front fairing off as I have a new right side that I am replacing. Everything is very easy with the exception of the bracket that at the bottom of the front of the bike that holds the left and rear together. It has two small plastic screws that you simply push in the middle but they don't work. Also there is a big plastic thing in the middle that I assume should come off as well and can't figure that out either and don't want to force or break anything. Any help here would be appreciated.
