1 - 5 of 5 Posts
rawx
I wanna replace the header gaskets when i do my 06/07 header swap. I tried to search but couldnt find where people are buying them. Local shops closed until tues for the 4th. Was gonna order online any help would be great.
if they arent burnt (which I doubt they are) reuse them. they will only leak if they are burnt
I reused my gaskets. The bike only had 800 miles on it so as long as your gaskets are not burnt or you see the aluminum on there your good. Or you could go get gasket maker and put it on there if you really wanted to. But if you bike has less than I would say 1500 miles you should be definitely in the clear for reusing your old gaskets. But don't forget to check and make sure that they are not leaking later on. If they are then yeah you will need new gaskets.
1 - 5 of 5 Posts
