OK i search and search, but cant find real answer. I have 2005 gsxr 1000. and i want to get into dealer mode to see my code. Where exactly is the plug located and what two pins need to be jumped? color would help thank you.
It reduces noise. All aftermarket exhausts will eliminate the SET valve as it is part of the stock pipe.:cheersWhat does that exactly do anyways?
So i can get a level one racing exhaut for about $300, and this will not just get rid of my FI(C46), but also i will get a exhaut i like.It reduces noise. All aftermarket exhausts will eliminate the SET valve as it is part of the stock pipe.:cheers
Yes as long as you disconnect the brown wire in the harness under the seat. :cheersSo i can get a level one racing exhaut for about $300, and this will not just get rid of my FI(C46), but also i will get a exhaut i live.unk
I took the cables off but left the servo mounted on the bike.:cheersshould i remove the servo and cabling when i get he exhaut or just leave it in the bike?
So then that connector is under front seat, which i found earlier.lol... now do you know what two wires need to be shorted?
