Status
Not open for further replies.
1,081 - 1,100 of 10,000 Posts
mike i have a hairline crack about an inch long on my intake manifold. it was leaking fluid from there when i would drive it. i put jbweld on it do u think it'll hold for a while? or should i try to have it welded?
If it's just on the water passage it should be fine. It won't see any more pressure than what your radiator cap is rated for.
its on the front on the water passage. I had recently took off the bolt in the front because i bought a autometer water temp gauge and installed it there. and i guess i overtightened it i thought i hadn't but when i installed it was fine but a few days later the crack appeared its right under the water neck. There's this bolt that goes in under the waterneck almost where the intake manifold meets the block
Status
You have insufficient privileges to reply here.
