1 - 3 of 3 Posts
Asfaraslogic
My low fuel level light no longer comes on when I run low on fuel. The light itself works, it lights up whenever I start the bike. Is there some kind of sensor in the tank? Can I change that? BTW its an 03 1K....:hammer
There is a thermistor, you can test it.
Unbolt it, plug 12 volt current with a tester inline(those like a pen with a light inside).There is one wire(+) and the shaft is the ground.
If it works, after 15-30 sec the tester should lights up slowly.
The thermistor is heating when there is no more fuel to cool it so the ECU send the signal to the speedo light.
PART # 10
http://www.ronayers.com/fiche/300_0345/fuel_pump/fuel_pump.cfm?man=su&groupid=5870&parent=5840
This part is very expensive from Suzuki so if it is really that, i suggest a new pump on Ebay.
1 - 3 of 3 Posts
