1 - 10 of 10 Posts
Yeah they should you just need to check out some other sites, cause it appears from there link that it is only providing limited bike selection, why??? Not sure I have always been able to go to the site and look up exactly what I wanted to for the biek I was researching for.
James
No you just bolt off your stock muffler (5 nuts/bolts) and then bolt the new muffler on.
If you're just replacing the muffler part, that's just a Bolt-On system. Isn't it? The Slip-On system has the pipe connecting to the muffler.
Yes th B/O is just the muffler & I'am not sure-but I don't think they offer a slip for the 04 6-besides the slip really would not be worth the $-perf wise
Discussion Starter · #7 ·
Ok, thanks, so I guess the choices are between Bolt-On of Full-System then.
If you want a slip on, you can get a GSXR1000 titanium header and then you can use a slip-on. Otherwise, you're stuck with either a bolt-on or a full system, and a full system wouldn't be worth the money on a 600.
Discussion Starter · #9 ·
Yea, it's definitely not worth doing the full system. But damn, I was hoping to get the high-exit exhaust! I guess I'll have to do some custom piping.
1 - 10 of 10 Posts
