1 - 2 of 2 Posts
I have a 2018 1000rz running the yoshimura em-pro 2.0 version- how can I get a copy of the "ryoyu" hamamatsu built factory race bike map file??? I have all the add on except the skins, rs11 exaust cams thin headgasket.... I am using the map file provided preset on the em-pro and am ready to flash a new map to it to match the hardware....
Anyone know anything about L8 models and yosh ECU?
if you dont have the cams the map will be way off - i do alot of cams and it changes the fuel map a good bit, also the ignition map may be changed some as well with running a different head gasket/bumping the compression.
i have tuned using the em pro but im not super acquainted with the t/c settings and such
jason
1 - 2 of 2 Posts
