I have a CF yoshi slip on my stock header right now. Im looking at this yoshi header but doesnt look like it has the proper end on it to attach the pipe. Is there a piece missing here that I would need to fit the pipe on?
does the pipe you have now bolt-on to the old stock header?
If yes, the pipe you have is not a "slip-on" but a "bolt-on" system that will not fit the header/mid-pipe on the picture without some creative welding.
the headers in the picture will usually come as a set that includes a "slip-on" system pipe that will attach to the mid-pipe.
[ 10-22-2002, 11:50 PM: Message edited by: migz123 ]
I've been wondering that if you found a beat up can(same model,just slipon type) and drilled the rivets out,would you be able to put that slipon piece onto your bolt on can(after you took the bolt on piece off)?Man,do I have a way with words
It would most likely work,eh?I think I'll try it.
Someday
yeah you need a mid pipe then the end pipe as well as with i think the older models they had it made on the end pipe so it looked longer also you need the brackets that hold header to head
[ 10-23-2002, 07:00 AM: Message edited by: audi1031 ]
The header you have there has a mid pipe on it... So all you need is the can..
