Hey all,
Can anyone offer any help to the installation of the yosh full system for my gixxer 750? Ive got the brackets and springs but am not sure if you need some sort or gasket to seal to the motor? Any help would be appreciated. thanks
You can usually use the header gaskets that the stock exhaust used. If you don't have any, you need 4.
header gaskets
-you may not need to replace these
-they are (4) rings, each go into, fit flush inside the engine exhaust port
i dont see the oem partnumber jumping out at me from the service manual
suggestion
put hi temp anti seize lubricant on the fastner threads on the way back in
i have permatex.com #133a this is not especially hi temp tho
keep everything lose till the final assembly, adj the exhaust away from the plstic faring.
