Having problems with my bike idling at low rpm but runs fine wide open throttle, I have one connector plug that I can't find anything to plug it into and I'm wondering could this be the problem or does this connector plug into anything at all? Here's a picture of the connector
Your best bet would be to try to locate the connector in the wiring diagram in the service manual, based on the wire colors.
Your pic is crappy enough that I'm not sure but there's a connector to the purge control solenoid that is only used on CA(E33) models. It otherwise hangs unconnected. The wire colors are O/W and Dbr. That might be yours.
Idle problems are commonly associated with the ISC valve. It can become clogged with deposits. The bike also won't idle properly if the clutch switch is faulty/disconnected/removed.
