I use 3 quarts even when I change the oil and filter. 3.1 is prolly the "correct" amount as someone else listed. It is usually up over the full mark with 3 so that is what I use. If not, try 2.5 and see where you are at, either way you are going to have to buy 3 quarts. Just change the filter and be sure of it.
actually.. if you look at the manual, make sure you check because it should be 3.1 for a bike w/ filter change. Also you want to always have the best filtration performance, and therefore it's worth the 12 bucks to change it.
This is an older thread, you may not receive a response, and could
be reviving an old thread. Please consider creating a new thread.
