1 - 2 of 2 Posts
I have a small wiring problem on my 1997 GSX-R 750. The rear brake doesn't activate the brake lights.
I have determined that the front brake activates the brakelights just fine. All bulbs are good.
I adjusted the switch several times, and even disconnected the spring from the pedal and worked the switch manually.
I tried a used switch, with the same results. I also tried a new switch.
I have tried the test light on both wires leading to the switch, and neither wire has power with the key off, on, or with the bike running.
Any help here?
dont wanna state the obvious, but did you test with the ignition on ??
with no voltage between the orage/green wire and an earth on the bike, just a case if tracing the wriring connecters back to the ignition.
1 - 2 of 2 Posts
