1 - 12 of 12 Posts
does anyone know if doing the 520 chain conversion and going two up in the rear sprocket (leaving the front stock) or even going 1 up in the rear will affect my actual speedometer reading?
how much will it be off?
thanx
the 520 conversion will not affect the mph, but changing the sprocket will (fron or back). i would recommend getting the yellow box to give you the correct mph www.blackrobotics.com
I'm not reading all of that,Riz what does it do??
86'JoeyGSXR1100R,soup2nutz,sprayed like a subway,blinging w/chrome,old skool!Doing wheelies from da' begining & never putting it down!Harlem Crew..
it adjusts the speedo for whatever percentage it's off from the actual speed. there are switches on the box that represent different percentage values. the directions tell you how to figure out the percentage of error, then you just flip the switches until they add up the percent that you are off and that's it. they come in different colors
cool,I wished my speedo worked in the first place!ha
that would make too much sense and be too easy for the manufacturer. hahaha
not by much because the speed is calibrated from the front sprocket and how fast it spins, so if you leave the front sprocket stock you should be all set,,,, i think!!!!
98 gsxr 600, Blue and White, D&D exhaust, 15/48 gearing with a 520 chain, K&N filters, rear fender elimanator kit, flush mount directionals, and polished rims!!!
Changing either sprocket will affect the speedo. The speedo is run off the countershaft sprocket, so think of it like riding a ten speed bike. When you're in tenth gear your peddling very slow, but moving fast. 1st gear peddling like crazy but hardly moving.
98 TLR
actually that's not quite accurate - if we were to draw that analogy, the tranny on the motorcycle would need to be between the front and rear sprockets, because that's where the gear ratios change on a bicycle.
since the countershaft sprocket is on the output shaft of the tranny, its rotational speed is directly proportional to the bike's forward speed. it won't spin faster and result in the bike moving slower, unless the chain is doing some serious jumping around on the sprockets.
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by jbad:
thanx
<HR></BLOCKQUOTE>
I'm a little dozy tonight (no comments please!) but I can't see where you've mentioned what model you have. If your bike was made prior to SRAD days, you've got nothing to worry about, since you speedo is mechanical and works off the rotations of the front wheel. Otherwise (ie later models) you do have to pick up the 'yellow' box to correct the output.
Fat Bastard's bike: '93 GSXR1100wp CDN version w/ thoroughly ridiculous # of mods :)
Jeff,
I see what you're saying, maybe it wasn't the best description.
But changing sprockets will affect how fast the countershaft spins at a given speed.
Say you're going 60mph in 6th gear, and with stock gearing the motor is spinning @ 4000rpm. If you go down a tooth in the front (or up a couple in the rear), the drive sprocket will have to spin faster to turn the driven sprocket at the same speed.
98 TLR
you're right about that.
also, on fuel injected suzukis, the ram air compensation is taken off the speed sensor signal - at higher speeds, the fi system injects a little more fuel. so if you drop the gearing significantly, the bike will run a tad richer, because the ecm thinks the bike is going faster than it actually is. but it's probably not a difference that you'd be able to feel.
the logical way for suzuki to do the ram air compensation would have been to use the map sensor, but for some reason, they didn't. according to the service manual the map sensor is only used in conjunction with engine speed only in light load situations to select the base fuel map. under higher loads, the throttle position sensor and engine speed are used to select the base fuel map, with other sensors used to determine if a little more or a little less fuel is required.
[This message has been edited by jeff (edited 02-09-2001).]
1 - 12 of 12 Posts
